Tubular Electrolytic Capacitor question
12/2/2009 6:53:48 PMFred
Have a Tubular Electrolytic Capacitor, 20+8 @150 v
It has 3 leads, black, red and yellow. I know black is negative but what color goes with the 20uf and 8uf? There are no markings on the capacitor telling what color each lead is, only + on one end and a black band on the other. I do not have a schematic for the radio. Is there a color code for these capacitor leads?
12/2/2009 7:59:11 PMThomas Dermody
Typically the larger capacitor is closer to the rectifier cathode, though not necessarily.
12/4/2009 4:26:08 PMAnthony Bitetto
:Have a Tubular Electrolytic Capacitor, 20+8 @150 v
:It has 3 leads, black, red and yellow. I know black is negative but what color goes with the 20uf and 8uf? There are no markings on the capacitor telling what color each lead is, only + on one end and a black band on the other. I do not have a schematic for the radio. Is there a color code for these capacitor leads?
Usually the red wire goes to the higher value capacitor first. If you have a capacitor tester you can prove if this is correct, as well as if it is usable.
Tony
12/4/2009 6:59:52 PMWarren
One quick way to check, is to use an ohm meter. The 20 MFD side will take longer to charge, and have a bigger kick when revercing the test leads.
