:I was in the local Hobby Lobby the other day and saw decal sheets for inkjet printers,made by testor's the price was 10 bucks for it ... has anyone seen or tried this yet? I was thinking for making my own decals instead of ordering from the net all the time, but will ink from a inkjet run if exposed to the water???
What will really test your creativity though, is when you attempt to make white or goldtone letters/graphics on a waterslide decal. Sure would like to hear that someone was successful in their attempt to do so.
For gold letters it'd be next to impossible to accomplish. If there were a way to print with glue, then you could put gold flake on top of that, but inkjet printers usually turn the ink to steam, and so if the ink were a watered down Elmer's, it'd probably be dry by the time you got the sheet out. Plus the heads might be gummed up.
If there were a way to grind up gold so that it was super fine, and then mix it with a clear ink substance (perhaps something carrying a very watered down Elmer's), then perhaps your inkjet could actually print gold, though I'm guessing that the jets are so small that they'd clog with the gold on a regular basis.
:For something like the Sunbeam shield decal you could first print it on a piece of paper. Then cut out a mask the size of the shield. Spray gold on the decal sheet through the mask at the position that you printed the logo on the sheet of paper, and then print over this, though the ink might not adhere to the gold. You might have to paint the red over the gold and only print the Sunbeam logo itself. ...Or else print the red and black parts of the decal first and then spray in the gold by using smaller masks so that the gold only goes where it should when the product is finished.
:For gold letters it'd be next to impossible to accomplish. If there were a way to print with glue, then you could put gold flake on top of that, but inkjet printers usually turn the ink to steam, and so if the ink were a watered down Elmer's, it'd probably be dry by the time you got the sheet out. Plus the heads might be gummed up.
:If there were a way to grind up gold so that it was super fine, and then mix it with a clear ink substance (perhaps something carrying a very watered down Elmer's), then perhaps your inkjet could actually print gold, though I'm guessing that the jets are so small that they'd clog with the gold on a regular basis.
:T.
:Making your own water-slide decals is fun and interesting.
:What will really test your creativity though, is when you attempt to make white or goldtone letters/graphics on a waterslide decal. Sure would like to hear that someone was successful in their attempt to do so.
:The hobby shop in my area sells a product that will soften the decal and cause it to form to all of the unevenness of the surface it's on. This works well on wooden surfaces. The decal will basically turn to goo and adhere to everything, and then harden that way. I'm not sure if it'll work with the inkjet decals, and it won't soften lacquer, but you can try.
:T.
:If you use the decal softener, you can get the wrinkles to lay down. I managed to get the words 'CHANNELS' and 'FINE TUNING' to curve around the knob on my DeWald television. They were supplied as straight decals. It wasn't extremely easy, and, upon close inspection, they aren't perfect, but the result is fair enough. Helps to be over dark mahogany.
:T.
http://www.hobbylinc.com/htm/flo/flof505401.htm
:::Elton,
:::Most ink is water based, and will dissolve/run when decal is placed in water. The trick is to overcoat the decal with nitrocelluous lacquer after print ink is dry. A couple mist coats, then a heavier coat will not dissolve the ink. A first heavy coat will cause the ink to blur a little. I've tried water based acrylic lacquers with poor success. As I've stated before, the clear unprinted water slide decal sheets have a thicker substrate, and will not dissappear into the background like preprinted decals after final overcoating finish. I've used both and the preprinted items from parts vendors is superior. If the decal is located so as not to reflect light or in an unconspicious area, the non dissappearing act may be acceptable.
:::marv
::::I was in the local Hobby Lobby the other day and saw decal sheets for inkjet printers,made by testor's the price was 10 bucks for it ... has anyone seen or tried this yet? I was thinking for making my own decals instead of ordering from the net all the time, but will ink from a inkjet run if exposed to the water???
:::I'm about to find out. My brother made some decals for a guitar he was making, and sprayed the decals with a couple of coats of lacquer before applying them. Then he sprayed the whole piece a few more times, and it looks really good. Well, I'm trying to make a couple of dial glass replacements, and I've got the decals, courtesy of my brother. And they have been sprayed with lacquer. Now I'm going to float them on to plexiglass, and use the result as replacements for the shattered glass ones. Two Philcos, in fact. Anyone else done this?
:Please let me know how it turns out... can you use any type of clear lacquer for this process?
::Elton,
::marv
::Elton,
::marv
