:Hi! I have an old 1930's radio with bakelite knobs. The knobs have the indicator pointers broken off of them and I would like to repair them. I've seen everything from JB weld to fiberglass resin recommended for repairing bakelite. I would like to hear suggestions, from those having experience in this area, as to what works and lasts.Thanks for any info.
: Bob Masse
Best Regards,
Bill Grimm
Best Regards,
Bill Grimm
www.PLASTEX.net
Good luck.
terry F
Best Regards,
Bill Grimm
::Hi Bob,
:: I work a lot with bakelite cabinets. I just use household glue. It holds and doesn't show. Not showing is important. I did one with JB Weld. It held all right but you could tell it had been repaired.
:: If you have a knob that is cracked down the middle, you may have to go with the JB Weld, though. Tensil strenght is important there.
::Best Regards,
::Bill Grimm
::Best Regards,
::Bill Grimm
::Hi! Bill,
: Thanks for reply.My knobs have the pointers missing completely so I can't just glue them back together.I have to build up the area where the pointers were and then shape them.It doesn't say anything about repairing plastic on the JB weld package so I was looking for advice of someone who experimented in this area. Do you think it would work well to actually add on to the knob? I appreciate your advice.
::Tks. Bob Masse
::Hi Bob,
::Best Regards,
::Bill Grimm
::Best Regards,
::Bill Grimm
::Hi! Bill,
::Tks. Bob Masse
I have great luck repairing bakelite with super glue, though you say that parts are actually missing.
:Also, JB Weld does work very well for repairing bakelite. You can mix in oil paints for color. If you are adhering some JB Weld to the edge of a knob, you may consider filing into the underside of the knob so that the JB Weld has something to grab onto (or the disc method Marv suggested). A wire running through the addition will also help to strengthen it. Mould a basic form with clay, and then file to your desired appearance.
:I have great luck repairing bakelite with super glue, though you say that parts are actually missing.
:T.
