Jesse: I don't know what schematic you're looking at but the one at Tech Preservation gives values for caps and labels pins, but it also indicates the key position which will let you number the pins if you find that helpful in interpreting the schema.
Andy
:::Can Someone give me some advice? I am currently trying to recap my father in laws old radio. When I look at the schematic I see something Ive never seen..
:::When I look at the tube sockets instead of pin numbers, Im seeing letters.. Like G, and H, which I assume is Grid and Heaters? I dont see P for plate, but can someone guide me? Also on this schematic, I see Caps listed as Stock numbers.. I see a three wax caps 2 of them are .005 @ 1000 .. This is still .005 mfd @ 1000 Volts? Thank you in advance for anyones help.
::Jesse: I don't know what schematic you're looking at but the one at Tech Preservation gives values for caps and labels pins, but it also indicates the key position which will let you number the pins if you find that helpful in interpreting the schema.
:Carl,
:Could you please pass that URL along for that site? Thanks in Advance.
This is still .005 mfd @ 1000 Volts? C38 . . . . . Coupling the plate of the AF amp to the 1st grid of the AF output tube I am taking the AF Amp 6SF5 and marking up its circular numbering around it. Starting at the index referencng of the tube key gap at the top.
Sir Jesse. . . . .
Preeeeecisely . . .Ready for the . . . . . .Rest of the story ?:
As is being encountered on this particular schematic,
Sh . . . Shield (In the case of a metal tube being used, a connection to the outer metal housing of the tube. . .its shield.)
F . . . . . Filament
K . . . . . Cathode
G . . . . . 1st Grid
SG . . . . Screen Grid
SuG . . . Suppressor Grid
And in the case of the specific case of the 6SA7:
OG . . . . Oscillator Grid
And in the case of the dual section diode of the 6H6:
K1 . . . . . Cathode of diode section 1
K2. . . . . Cathode of diode section 2
A1. . . . . Anode (Plate) of diode section 1
A2. . . . . Anode (Plate) of diode section 2
For sure the C43 is one of them with it being subjected to the full peak to peak excursions of voltage across the AF output transformer, if being at high audio levels.
Some other, more critical application caps are:
C40 . . . . . Tone shaping capacitor of the AF amp
C31 . . . . . AVC decoupling /time constant capacitor
C33 . . . . . AF coupling capacitor
C49 . . . . . AF coupling capacitor
PLUS . .I'll just bet that you didn't have ALL of the plug ins for Deja Vu acquisition of this schematic, so I have pulled and posted it.
Sir Jesse. . . . .
K . . . . . Cathode
RCA Model 17K:
....And amazingly that paragraph is all one sentence, and it doesn't seem to run on, either! I don't know how I managed to do that.
Was this saying something to me? As in something rather curt, or being cute?
T>
