formPlastiс disk for tuning Midwest 37-11
11/17/2009 2:24:39 PMalexander vinyar
Plastiс disk for tuning is wave deformed. Can I make it flat? May be I can to heat it?
11/17/2009 10:13:03 PMEddie
:Plastiс disk for tuning is wave deformed. Can I make it flat? May be I can to heat it?
11/17/2009 10:21:18 PMEddie
Eddie
11/18/2009 1:01:19 AMalexander vinyar
::Plastiс disk for tuning is wave deformed. Can I make it flat? May be I can to heat it?
:I heard the safest and best option is to flatten the dial inside of a heavy book - if the dial is off of the radio. AFter a couple of months - it should be flat. If you think it needs to be heated - proceed very carefully. Again - put it inside a book, and protect both sides of it with plain white typing paper. Put it in an oven at it's lowest temperature, like 140 Farenheit, for a few minutes, then let it cool for a half hour before you remove it from the book and check it. It might even be safer to try 120 Farenheit first. I have a Midwest 18-36 with a slight warp in it's dial - I will probably flatten it this way if I ever take it off the radio. While the dial is off the radio - it sure is a convenient time to make a computer scan of it in case you need the artwork later.
:Eddie
