Power supply for battery sets
11/8/2009 9:32:50 PMBob B(81195:0)
I would like to build 2 or 3 solid state power supplies to power battery sets, typically 5 or 6 tube 01A' or 199 tubes.
If anyone can point me to a diagram source with component values it would be appreciated. I have one of those ARBE power supplies for bench use but would like to build individual supplies that can be left in a radio.
11/8/2009 10:08:50 PMJGJ(81196:81195)
Try looking here for AES schematic.....
http://www.antiqueradios.com/forums/viewtopic.php?t=105896
11/9/2009 12:22:20 PMTerry Decker(81213:81196)
:Try looking here for AES schematic.....
:http://www.antiqueradios.com/forums/viewtopic.php?t=105896
Terry
11/9/2009 9:32:20 PMBob B(81229:81213)
Thanks JGJ and Terry. I tried AES Search and came up blank. I will phone them.
11/9/2009 10:22:38 PMTerry Decker(81230:81229)
:Thanks JGJ and Terry. I tried AES Search and came up blank. I will phone them.
www.tubesandmore.com
Kit # K-101-A
11/9/2009 11:20:09 PMEdd(81233:81230)
Sir Bob . . . . .
Its sort of well . . . .hidden out . . . .
(But I personally, would still be building my own from scratch)
Onward. . . to more info on specs . . .
[ [ [ Hot Linkamus Referencing ] ] ]
::Thanks JGJ and Terry. I tried AES Search and came up blank. I will phone them.
:Sorry- go to
:www.tubesandmore.com
:Kit # K-101-A
11/10/2009 8:06:40 AMBob B(81246:81233)
I fear if I were to try building from scratch I would find myself in ept, deep ept. I have ordered one of those suckers from AES. Perhaps I can build a couple copies from it.
It's an ugly thing. I certainly can improve on that.
11/11/2009 1:01:24 PMTerry F(81289:81233)
Edd,
In the absence of a power supply (which I intend to procure/build), where does one start, in the meantime, troubleshooting a battery powered radio such as a Philco 42-122 which I recently inherited?
http://www.nostalgiaair.org/PagesByModel/505/M0013505.pdf
As always, thank you for your valuable help.
Terry F
11/11/2009 1:28:34 PMJGJ(81290:81289)
I'm not Edd - but I'll offer my $0.02. You could test the tubes with a tube tester, check the values on the resistors and pots with a meter (replace if necesary), replace the necessary caps, check coils with a meter, check solder joints and switches, etc., etc., etc.... BUT - without a power supply - what's the purpose??? - it ain't gonna play!!! I have generally found it much easier to work on a radio with a viable power supply - not only to check voltages at different points - but also to test the radio after each component change to make sure I haven't screwed up somewhere along the line. If you've made a dozen 'corrections' without a power supply and one of them was wrong - you've multiplied the difficulty of the final repair exponentially..... Bottom line - get a power supply BEFORE you start mucking around in the radio....
11/10/2009 12:09:14 AMNorm Leal(81236:81195)
Hi Bob
I can email you some general information on building such a supply, need email address. Not hard to build from mostly junk box parts. I do suggest using a LM317 voltage regulator for the filament supply.
:I would like to build 2 or 3 solid state power supplies to power battery sets, typically 5 or 6 tube 01A' or 199 tubes.
:If anyone can point me to a diagram source with component values it would be appreciated. I have one of those ARBE power supplies for bench use but would like to build individual supplies that can be left in a radio.
:Thanks
11/10/2009 8:08:26 AMBob B(81247:81236)
Thanks for the offer.
barkerbin@earthlink.net
11/10/2009 12:26:00 PMTerry Decker(81259:81247)
:Thanks for the offer.
:barkerbin@earthlink.net
11/10/2009 9:52:29 PMPaul Knaack(81278:81236)
:Hi Bob
: I can email you some general information on building such a supply, need email address. Not hard to build from mostly junk box parts. I do suggest using a LM317 voltage regulator for the filament supply.
:Hi Norm, could you please email me a copy of the information also? Thanks much, Paul
11/11/2009 9:10:13 PMPaul Knaack(81304:81278)
::Hi Bob
:: I can email you some general information on building such a supply, need email address. Not hard to build from mostly junk box parts. I do suggest using a LM317 voltage regulator for the filament supply.
Hi Norm, I received the email, thank you, looks simple enough and I have most of the parts. Thanks again, Paul
11/11/2009 11:53:01 PMTerry Decker(81315:81304)
:::Hi Bob
::: I can email you some general information on building such a supply, need email address. Not hard to build from mostly junk box parts. I do suggest using a LM317 voltage regulator for the filament supply.
:Hi Norm, I received the email, thank you, looks simple enough and I have most of the parts. Thanks again, Paul
1terrydecker@insightbb.com
t.
