Dial indicator decals
11/8/2009 4:38:06 PMFred
Have a wooden radio case that needs to be refinished. The dial indicator is a decal. There are no replacements available for this radio. I know the decal cannot be disturbed, but the area around it is all scratched and flaking. Has anyone had experience with this problem?
11/8/2009 7:06:05 PMSteve - W9DX
If it's flat maybe you can scan it, and make a new one after cleaning it up and improving it with Photoshop or other imaging software.
Steve
11/11/2009 12:14:45 AMMarv Nuce
Fred,
You can find clear (unprinted) waterslide decal material on the web. Comes in std size sheets, for PC printers. I use MS Visio and Adobe PS to make decals for dials or other needs, but the application used is your choice.
HERE IS A TIP
The substrate mat'l used for preprinted decals from most vendors is very thin, and will practically disappear when overcoated with a clear finish. I've found the waterslide sheets available on the web seems much thicker, and consequently don't dissappear into the finish. A line of demarcation will be obvious at the decals edge. Typically a decal is overcoated with a clear finish, but if the placement of the decal is on a highly reflective surface, the line of demarcation may be objectionable. I've used waterslide decal materials from 2 different mfrs, and both are too thick for a really finished look.
:Have a wooden radio case that needs to be refinished. The dial indicator is a decal. There are no replacements available for this radio. I know the decal cannot be disturbed, but the area around it is all scratched and flaking. Has anyone had experience with this problem?
