I would like it to supply 45, 90 and 135 volts. Bias voltage would be nice but I could always use modern batteries for that.
Initial application intended for a Radiola 20, a Grebe Synchrophase and a Kellogg if I can ever find tubes for it.
You could build if from scratch with parts bought separately. But the individual parts may cost more than the kit?
http://www.portabletubes.co.uk/sitefiles/ausbatt.htm
http://www.batpack.com/
If you are looking for AC Powered supply, check
http://www.tubesandmore.com/ search under "Power Supply kit"
Here is another link for a similar supply circuit:
http://www.ka7oei.com/ak20c_ps.html
:I would like to build 2 or 3 solid state power supplies that can be permanently installed in battery sets. Can anyone point me to a diagram with specs for such an animal?
:I would like it to supply 45, 90 and 135 volts. Bias voltage would be nice but I could always use modern batteries for that.
:Initial application intended for a Radiola 20, a Grebe Synchrophase and a Kellogg if I can ever find tubes for it.
