Hey, any of youse guys out there got any amplifier schematics that are using an (old family) 807 tube ? Well, this one ##### happens to be using a parallel pair of them and is for CW but it could be just using one tube. One nice thing that it is using a pi section output section and just might match to anything from a 108 inch CB whip antenna on up to an electric fence wire. ##### (CLICK ON Schematic, if required,To MAG on up in its sizing) |
por fabor si alguien me puede pasar circuitos para un amplificador con esta valvula
Bill
IPAddress: ***.172.209.72
: ![]() : : : : : :Sir Guido. . . . . : : : : : : : : :por fabor si alguien me puede pasar circuitos para un amplificador con esta valvula : : : :Literally as . . . . . . : : : : :Please, if anyone could help me, in passing to me, any circuits for an amplifier using this tube. : : : :aka . . .if you don't speaka da speak . . . : : : :Hey, any of youse guys out there got any amplifier schematics that are using an (old family) 807 tube ? : : : :And I certainly hope that you are considering an RF amplifier and not for its being used as an Audio power output amplifer!) : : : : :Well, this one ##### happens to be using a parallel pair of them and is for CW but it could be just using one tube. One nice thing that it is using a pi section output section and just might match to anything from a 108 inch CB whip antenna on up to an electric fence wire. : : : :You will need to alter the tuned L/C values for the frequency involved, efficiently on upwards to 10 meters. Or the additional incorporation of a modulator scheme *****, if wanting to use other than CW. : : : : :##### (CLICK ON Schematic, if required,To MAG on up in its sizing) : : : : :****** : : :Power amp output amplifier circuit, with an AM modulator, is located at : : : :http://www.amwindow.org/tech/htm/wb9eckseriesmod.htm> : : : : : : : :73's de Edd : : : ![]() : |
