11/5/2009 10:38:24 AMDaveF(81117:0)
Unfortunately I do not have a CTR tester, but recently acqired a Dumont CRT that I would like to see if it is any good, can I plug it into the socket of my Admiral set that takes a 12LP4 to test it somehow? I dont want to work on restoring the Dumont if my CRT is bad, at least not in the near future.
11/5/2009 2:50:26 PMCodefox(81120:81117)
:Unfortunately I do not have a CTR tester, but recently acqired a Dumont CRT that I would like to see if it is any good, can I plug it into the socket of my Admiral set that takes a 12LP4 to test it somehow? I dont want to work on restoring the Dumont if my CRT is bad, at least not in the near future.
11/5/2009 2:53:09 PMCodefox(81121:81120)
::Unfortunately I do not have a CTR tester, but recently acqired a Dumont CRT that I would like to see if it is any good, can I plug it into the socket of my Admiral set that takes a 12LP4 to test it somehow? I dont want to work on restoring the Dumont if my CRT is bad, at least not in the near future.
:Googled both and they pin out the same. Test for filament continuity pins 1 and 12 before spending a lot of time going further.
