I certainly did, and gave them back to you waaaaay back on : |
:Here's the problem.. NO FM.. No stereo, NO FM.. Am works VERY VERY WELL.. I noticed a hum that became even more pronounced when putting in a new 6AQ8 tube..
:So found the hum becomes even worse when touching a round mica cap that connects to the switch that connects to the volume control. Anyone got any ideas where to look.. Where to start.. Again AM WORKS WELL.. FM IS NONE>>>>> HELP?????????????????
: ![]() : : : : : :Sir Jesse. . . . . : : : : : : : : :Anyone got any ideas where to look.. Where to start. : : : : :AM WORKS WELL.. FM IS NONE>>>>> HELP????????????????? : : : :You been associating with G berg ? : : :(Jes' messin' wit' your mind ) : : : :I certainly did, and gave them back to you waaaaay back on : : : :http://www.nostalgiaair.org/forums/Messages/963/M0078963.htm : : :No comeback on testing what-sum-ever . . . . : : : : :We KNOW with what you info that HAVE given us, that the set is in order in its power supply, and the audio amplification stages and the speaker. : : : : :Now in going back to my initial help offering and ALSO there is the additional need for the checking of the presence and voltage level of all B+ feeds to tube screen grids and plates of the sets frontal RF tubes . Compare the resultant readings against the schematic estimated values. : : : :Pee Ess . .gettting the plate readings on the 6AQ8 can be accomplished by taking a single strand of AC line cord's bare copper wire. Then you do a tweezer twirling of a few turns around each of the the plate pins, with two separate wires and separate and tape across them at the top of the tube to hold them taut against the envelope. : : :Then place an insulative tab of paper between the bare wires and the tube shield. plug in, fire up and take your readings :up at the exposed wire ends. : : : :Now, we are trying to ascertain the sequential link down the FM section that is failing. : : : :When you monitor at the 1st grid of the limiter tube, (That is pin 1 of the V5-6AU6 tube) you can confirm that all of the FM frontal RF string up to that point is OK. : : : :It lets you know, by the presence of a negative voltage there. Expect, that as you tune into a FM station, the negative level will rise and peak as you are " right on " the station, then the reading will diminish as you tune on past and off from the station. : : : :The level of - reading is proportionate to the strength of the signal. : : : :The highest negative voltage readings will be experienced from your very strongest stations. : : : : Then, if you are finding swinging voltage levels with the tuning in to stations, YOU'SE GOTS a working FM radio . .UP to that circuit point, and we need to be moving on to the evaluating of the FM detector stage, as that is the next stage before reaching your audio, which you have already confirmed as working. : : : : : : :Initial HOT reference thread . .hottamus link-a-caticized . . .: : : : : :Rotomola / Quasar B-100 : : : : : : : : : : :73's de Edd : : : ![]() : |
::Sir Jesse. . . . .
::Anyone got any ideas where to look.. Where to start.
::AM WORKS WELL.. FM IS NONE>>>>> HELP?????????????????
::You been associating with G berg ?
::(Jes' messin' wit' your mind )
::I certainly did, and gave them back to you waaaaay back on :
::http://www.nostalgiaair.org/forums/Messages/963/M0078963.htm
::No comeback on testing what-sum-ever . . . .
::We KNOW with what you info that HAVE given us, that the set is in order in its power supply, and the audio amplification stages and the speaker.
::Now in going back to my initial help offering and ALSO there is the additional need for the checking of the presence and voltage level of all B+ feeds to tube screen grids and plates of the sets frontal RF tubes . Compare the resultant readings against the schematic estimated values.
::Pee Ess . .gettting the plate readings on the 6AQ8 can be accomplished by taking a single strand of AC line cord's bare copper wire. Then you do a tweezer twirling of a few turns around each of the the plate pins, with two separate wires and separate and tape across them at the top of the tube to hold them taut against the envelope.
::Then place an insulative tab of paper between the bare wires and the tube shield. plug in, fire up and take your readings
::up at the exposed wire ends.
::Now, we are trying to ascertain the sequential link down the FM section that is failing.
::When you monitor at the 1st grid of the limiter tube, (That is pin 1 of the V5-6AU6 tube) you can confirm that all of the FM frontal RF string up to that point is OK.
::It lets you know, by the presence of a negative voltage there. Expect, that as you tune into a FM station, the negative level will rise and peak as you are " right on " the station, then the reading will diminish as you tune on past and off from the station.
::The level of - reading is proportionate to the strength of the signal.
::The highest negative voltage readings will be experienced from your very strongest stations.
:: Then, if you are finding swinging voltage levels with the tuning in to stations, YOU'SE GOTS a working FM radio . .UP to that circuit point, and we need to be moving on to the evaluating of the FM detector stage, as that is the next stage before reaching your audio, which you have already confirmed as working.
::Initial HOT reference thread . .hottamus link-a-caticized . . .:
::Rotomola / Quasar B-100
::73's de Edd
:::Here's the problem.. NO FM.. No stereo, NO FM.. Am works VERY VERY WELL.. I noticed a hum that became even more pronounced when putting in a new 6AQ8 tube..
:::So found the hum becomes even worse when touching a round mica cap that connects to the switch that connects to the volume control. Anyone got any ideas where to look.. Where to start.. Again AM WORKS WELL.. FM IS NONE>>>>> HELP?????????????????
:I didnt quite get the part about bare wire.. BUT ok , I will again look at the schematic and values and get back.. Its been a while since I last looked at this radio and I just want to be able to make heads or tails of this.
