dogbone resistors
11/3/2009 4:11:04 PMscott
working on philco model 296. the color code is confusing me. i have a solid green resistor measures 167k. according to the color code green should be 5, but there are no other colors to give me the rest of the number. a couple of other resistors have metal end caps and are grey bodies with yellow stripe at one end, but no dot or other stripe for the multiplier. these also measure way off what the color indicates. My schematic for this model does not include part values so any help will be great. Thanks
11/3/2009 5:31:57 PMphil
hi,try this one from ron's site;
http://www.philcoradio.com/tech/images/296.jpg
:working on philco model 296. the color code is confusing me. i have a solid green resistor measures 167k. according to the color code green should be 5, but there are no other colors to give me the rest of the number. a couple of other resistors have metal end caps and are grey bodies with yellow stripe at one end, but no dot or other stripe for the multiplier. these also measure way off what the color indicates. My schematic for this model does not include part values so any help will be great. Thanks
11/4/2009 5:03:54 PMscott
thanks for the schema, now im trying to trace some wires that run through a cloth wire harness
:hi,try this one from ron's site;
:http://www.philcoradio.com/tech/images/296.jpg
::working on philco model 296. the color code is confusing me. i have a solid green resistor measures 167k. according to the color code green should be 5, but there are no other colors to give me the rest of the number. a couple of other resistors have metal end caps and are grey bodies with yellow stripe at one end, but no dot or other stripe for the multiplier. these also measure way off what the color indicates. My schematic for this model does not include part values so any help will be great. Thanks
