king hinners model 25 neutrodyne
11/1/2009 8:57:38 PMcarl z
hello all, i have a king hinners model 25, five tube radio. i dont have much experience with radios like these, as this is the only neutrodyne that i have. just a question out there for those more experienced with these, what kind of antenna is the best to use with these, or gives the best performance. the radio does work but just wondering what kind of antenna might boost performance a bit. (i am using around 20 feet of wire outside my home, space outside is a concern) thanks much carl z
11/2/2009 1:23:06 PMWarren
Might try this. Use your active telephone land line wire. make a multi turn loop in it. wrap another piece of wire around it. Leave one end open, the other end to the radio antenna input. Makes a good lose coupling antenna.
11/2/2009 4:18:06 PMcarl z
:Might try this. Use your active telephone land line wire. make a multi turn loop in it. wrap another piece of wire around it. Leave one end open, the other end to the radio antenna input. Makes a good lose coupling antenna.
