Motorboating on FM on Philco 48-482.
11/1/2009 8:53:59 PMMicro9
Need help on a Philco 48-482.BC and SW work great after recap but FM is very weak and motorboats when volum is rasied.FM was bad before I recapped it.All resistors are with in tolerance around the FM1000 and 7B6 tube.....Any ideas????
11/2/2009 10:51:27 PMMicro9
:Need help on a Philco 48-482.BC and SW work great after recap but FM is very weak and motorboats when volum is rasied.FM was bad before I recapped it.All resistors are with in tolerance around the FM1000 and 7B6 tube.....Any ideas????
11/3/2009 12:29:28 AMBill Mc
::Need help on a Philco 48-482.BC and SW work great after recap but FM is very weak and motorboats when volum is rasied.FM was bad before I recapped it.All resistors are with in tolerance around the FM1000 and 7B6 tube.....Any ideas????
:FIXED....A new e-cap went bad...checked it before I put it it checked good...went bad when the power hit it.....
11/3/2009 1:44:13 PMMicro9
:::Need help on a Philco 48-482.BC and SW work great after recap but FM is very weak and motorboats when volum is rasied.FM was bad before I recapped it.All resistors are with in tolerance around the FM1000 and 7B6 tube.....Any ideas????
::FIXED....A new e-cap went bad...checked it before I put it it checked good...went bad when the power hit it.....
11/3/2009 9:51:56 PMBill Mc
::::Need help on a Philco 48-482.BC and SW work great after recap but FM is very weak and motorboats when volum is rasied.FM was bad before I recapped it.All resistors are with in tolerance around the FM1000 and 7B6 tube.....Any ideas????
:::FIXED....A new e-cap went bad...checked it before I put it it checked good...went bad when the power hit it.....
:Bill...Do have the FM antenna wrapped around the Power cord???Mine was missing when I go it so I had to make another....
