AIWA subwoofer shuts down
10/30/2009 10:15:43 PMTerry Decker
I picked this subwoofer up in the alley- don't laugh, you'd be AMAZED at how much I've made off of eBay from this alley. I live near U. of L. and these kids throw stuff out when it gets dirty. Anyway- it had low output, and after a while it shut down. It has an STK 4132II stereo output IC. Simple, replace the amp, right? It still shut down. Ah, I re-used the thermal grease, must be the problem! -Nope!
I have the schematic, but it's tiny. So tonight I'll enlarge it and tomorrow check for DC offset at the output. Any other ideas would be appreciated. Thanks, Terry
10/30/2009 11:02:05 PMTerry Decker
:I picked this subwoofer up in the alley- don't laugh, you'd be AMAZED at how much I've made off of eBay from this alley. I live near U. of L. and these kids throw stuff out when it gets dirty. Anyway- it had low output, and after a while it shut down. It has an STK 4132II stereo output IC. Simple, replace the amp, right? It still shut down. Ah, I re-used the thermal grease, must be the problem! -Nope!
: I have the schematic, but it's tiny. So tonight I'll enlarge it and tomorrow check for DC offset at the output. Any other ideas would be appreciated. Thanks, Terry
Terry
10/31/2009 2:10:09 AMWarren
Have been into a Aiwa subwoofer before. They have a power transformer, regulator circuit, and zener diodes. If it shuts down, it's because the voltage is running high. Look on that tiny print you say you have with a magnifier glass. Check the regulator. It is probably shorted. Will also toast little low value resistors too.
10/31/2009 2:10:28 PMTerry Decker
:Have been into a Aiwa subwoofer before. They have a power transformer, regulator circuit, and zener diodes. If it shuts down, it's because the voltage is running high. Look on that tiny print you say you have with a magnifier glass. Check the regulator. It is probably shorted. Will also toast little low value resistors too.
10/31/2009 4:42:11 PMTerry Decker
10/31/2009 5:10:41 PMWarren
Don't know what model you are working on. Some are more sophisticated. The few I have worked on were heavy and powerful. had regulators, zener diodes, and a lot more circuitry than you describe. I would think your filter capacitors are okay, if they were holding a charge.
10/31/2009 6:44:25 PMTerry Decker
:Don't know what model you are working on. Some are more sophisticated. The few I have worked on were heavy and powerful. had regulators, zener diodes, and a lot more circuitry than you describe. I would think your filter capacitors are okay, if they were holding a charge.
11/4/2009 1:30:49 PMTerry Decker
::Don't know what model you are working on. Some are more sophisticated. The few I have worked on were heavy and powerful. had regulators, zener diodes, and a lot more circuitry than you describe. I would think your filter capacitors are okay, if they were holding a charge.
:Yeah, you're probably right. It's really cheap junk, (50 watts), and I should eat the $17 I've got in the STK and forget it. But I'm sure you also hate to get into something and not fix it. I've always said that- "give me enough time and the right test equipment, and I'll fix it". Sometimes, though, it's good to know when to quit. Thanks for your support. Terry
WOW! You should see the stir I caused on the ARF forums section. Who knew???
Got any ideas on a Philips TV shut down after power lite starts blinking? Just askin'
Seems I'm having shut down syndrome!!
Terry
11/4/2009 2:44:31 PMWarren
Re-solder all the pins on the fly-back transformer to the PC board. Check the CRT socket to PC board too.
11/4/2009 3:21:52 PMterry Decker
:Re-solder all the pins on the fly-back transformer to the PC board. Check the CRT socket to PC board too.
Thanks, Terry
