You put in soooo many points of interest, that I am just going to have to bisect them apart, covering point by point. AAAAHAAA . .now that broke off tip now reminds me of the day one generation of the Ungar family of irons with their screw in cartridges and the acceptance of a 6/32 screw in tip. One might remember its profile better as its version with the larger screw in Hmmmm, now you have me wondering about that source of purchase, where I initially would thinking of a "Premium Brewed" Full Service hardware store with its metal supply area where they have all families of metal cut up into 2, 3 or 4 feet chunks. OK now here is where I came in with the SAME identical situation, but its origin was back in 1968, when I then though that $1.95 was outrageous for a soldering iron tip. There are some anti-sieze agents offerd by some soldering supplies manufacturer, but even those are limited in their effectivity |
A tip tip: To prevent the tip threads from seizing in the iron when it comes time to change the tip, I put a dab of (Permatex) anti-seize on the threads before installing it.
When I see some of the prices out there to service parts on an iron, it's worth it to buy a new iron.
Great idea on the tips.
:Bought this Weller handle and 33 Watts heating element with tip about a year ago. Very pleased with it. Few days ago the tip broke off flush with top of element. I got it out all right but looked in Mauser for new tips and saw $4.00-5.00 price tag! Mauser is usually pretty good on price but thought I check here. Also, based on that price, I picked up a "pure" copper 1/8" rod 36" long for $1.50. Expect to make 30 tips out of that rode. All I have to do is thread rod 6/32 and grind chisel or point tip. Any comments or suggestions on making the tips that way? If it works, that's thirty tips for $1.50! PL
Just a passing note about your fabricated tip. If you will use a 1/8 inch brass brazing rod for your material instead of copper your tip will hold up much better. Brass is an alloy of copper and zinc and the heat conductivity is just fine although not quite as good as pure copper. Tom
::Bought this Weller handle and 33 Watts heating element with tip about a year ago. Very pleased with it. Few days ago the tip broke off flush with top of element. I got it out all right but looked in Mauser for new tips and saw $4.00-5.00 price tag! Mauser is usually pretty good on price but thought I check here. Also, based on that price, I picked up a "pure" copper 1/8" rod 36" long for $1.50. Expect to make 30 tips out of that rode. All I have to do is thread rod 6/32 and grind chisel or point tip. Any comments or suggestions on making the tips that way? If it works, that's thirty tips for $1.50! PL
:Just a passing note about your fabricated tip. If you will use a 1/8 inch brass brazing rod for your material instead of copper your tip will hold up much better. Brass is an alloy of copper and zinc and the heat conductivity is just fine although not quite as good as pure copper. Tom
I even make the smooth soldering tips for my Weller 8200 soldering guns from solid #10 copper wire. I measure a length of wire, flaten a portion of the wire and then bend and shape it like a regular $4 for two tip. Flux and tin and I am ready to go for only a few cents.
:OK guys, thanks. The supplier = smallparts.com has a lot of interseting stuff. Was suprised by low price on rod. I think I would prefer some type alloy so copper not as soft but for price I'm satisfied. I had an Unger for 20 year but dropped it, glued it together with ceramic cement but it gave up the ghost. Couldn't find similar Unger, saw the Weller was similar and hoped it will last as long (MOUSER by the way). I have been using silicon grease but I need a higher temp then the one I have. Thinking the no-stick stuff for spark plug threads. Edd, that some care you give the irons, but obviously from their longevity, they appreciate it. Oh, the iron element is 33 watts and yes that is odd. PL
:::Bought this Weller handle and 33 Watts heating element with tip about a year ago. Very pleased with it. Few days ago the tip broke off flush with top of element. I got it out all right but looked in Mauser for new tips and saw $4.00-5.00 price tag! Mauser is usually pretty good on price but thought I check here. Also, based on that price, I picked up a "pure" copper 1/8" rod 36" long for $1.50. Expect to make 30 tips out of that rode. All I have to do is thread rod 6/32 and grind chisel or point tip. Any comments or suggestions on making the tips that way? If it works, that's thirty tips for $1.50! PL
::Just a passing note about your fabricated tip. If you will use a 1/8 inch brass brazing rod for your material instead of copper your tip will hold up much better. Brass is an alloy of copper and zinc and the heat conductivity is just fine although not quite as good as pure copper. Tom
