Steve
:The old unit was not stereo. Was only Mono. The Old 3 pin connector, two pins were from the cartridge, the third pin is ground. You can rewire the stereo cartrige as mono. And still be able to use the three pin connectors.
Steve
:That " Green " wire is to ground the motor mountings and tone arm mechanics with the common grounds of the amplifier. Without that the amp picks up hum.
I feel sure that the old style of mini-ovaloid-black connector plug which RCA used to use, is that to which
:Okay then. Your 1956 unit is known as Ortophonic. As far as I knew true stereo came out from RCA in 1958. But if your old turntable is stereo, and has a 3 pin connector from the phono cartridge to the audio input on the amp. You can take an ohm meter, find the 2 pins on the 3 pin connector that are the left, and right channel. The 3rd pin would be shared by both channels.
: Cut off the RCA male ends on the new turntable. Connect the outside shields together. Connect the shielded wires now to that 3rd shared pin. The outer 2 wires now connect to the left, and right pins on the old 3 pin connector, from the old turntable.
