How can you connect permanent magnet loudspeaker to ATWATER KENT model 42
10/27/2009 11:34:23 PMChris
Hello all. Is it possible to hook up a permanent magnet speaker to Atwater Kent model 42 by substituting the speaker choke and capacitor with a single ended output transformer .Would this effect the power supply filtering and would you have to make further modifications??How would you do this?Thanks for any info.
10/27/2009 11:40:17 PMNorm Leal
Hi Chris
The speaker choke and capacitor are built in the radio. If they are still there just leave them in the circuit.
Connect a moderm permanent magnet speaker with output transformer to speaker posts in your Atwater Kent Model 42. It will work. Type of output transformer isn't critical.
:Hello all. Is it possible to hook up a permanent magnet speaker to Atwater Kent model 42 by substituting the speaker choke and capacitor with a single ended output transformer .Would this effect the power supply filtering and would you have to make further modifications??How would you do this?Thanks for any info.
