tube 77/78
10/27/2009 11:36:42 AMfrank
Does anyone think that a 78 tube may make a substitute for a 77 in a Philco 80
Frank. Doncaster England
10/27/2009 10:46:09 PMNorm Leal
Hi Frank
Each 77 in this radio is used as a detector. A sharp cutoff tube like 77 works better than 78, remote cutoff type. You can try a 78 but signal volume may be low.
Do you have a 6C6? This tube will work in place of a 77 but may require a taller shield.
If you can't find a 77 or 6C6 email for address.
:Does anyone think that a 78 tube may make a substitute for a 77 in a Philco 80
:Frank. Doncaster England
10/29/2009 1:32:42 PMfrank
Norm. Many thanks for the info. I do have a couple 6C6. I will use this as the replacement - but I have lots of 78's
Thanks again. Frank.
:Hi Frank
: Each 77 in this radio is used as a detector. A sharp cutoff tube like 77 works better than 78, remote cutoff type. You can try a 78 but signal volume may be low.
: Do you have a 6C6? This tube will work in place of a 77 but may require a taller shield.
: If you can't find a 77 or 6C6 email for address.
::Does anyone think that a 78 tube may make a substitute for a 77 in a Philco 80
::Frank. Doncaster England
