:Hello All,
: With the load removed and the resistor replaced I cannot get the relay to energize again. What's going on? Does there have to be a plug-in in the scope for the relay to energize? If no I can work with the scope until I get some tubes for another plug-in that I have.
: The relay was energizing but after the load returned, it absolutely refuses to energize. Is the delay relay damaged or should I check something else?
:Thanks,
:Dave
:Hello Again All,
: I guess that the relay is out of adjustment because I measure 94 ohms between pins 6 and 9 of the delay relay when the scope is off. Those relay contacts have to make a better connection to get the delay relay to heat and turn on and disconnect the delay it's filament and connect the coil in the relay. I believe that that's how it works.
:Thanks,
:Dave
::Hello All,
:: With the load removed and the resistor replaced I cannot get the relay to energize again. What's going on? Does there have to be a plug-in in the scope for the relay to energize? If no I can work with the scope until I get some tubes for another plug-in that I have.
:: The relay was energizing but after the load returned, it absolutely refuses to energize. Is the delay relay damaged or should I check something else?
::Thanks,
::Dave
But I now see that you are referring to the time delay relay, it is a thermal heater-bi metallic strip type of unit which gives time for the sets filaments to warm up before switching in most of the main B+ supplies of the set.
73's de Edd ![]() |
Mark-Up . . . . Working. . . . .Tektronix CA Preamp- Plug In Schematic : ![]() |
