I would look at these as possible sources, plus you might want to flip the plug in the outlet. Sometimes this alone will do the trick on an AC/DC radio.
: Hello my RCA Victrola X624 is fixed thanx Renee and Denis! However, the filter caps have been replaced and like my other RCA Victrola 9Y5 it has a slight hum a little to loud for my liking I think it's 60 cycle and as I like to listen to AM before I go to sleep I tend to listen at low volumes therefore the hum is more apparent at these times. Are there any mods or maybee wire positioning changes that may improve on this or is it just inherant to this type of transformerless radio design? My other question is, both of these amps have no input or power transformer and have 12 and 35 volt filaments is this what you guys mean when you say it's an ac/dc radio?? If this where a guitar amp which I work on all the time I would check the filter caps but I just put new filter caps in both radios although I used a 100uF instead of the 80uF 150 that I replaced and a 47 instead of a 50uF 150V. Thanx Brian
