Thank you in advance.
Nick Bettis
The Atwater Kent 60 uses: 3 - 24, 2 - 27, 2 - 45 and 1 -80 tubes. The actual numbers in your radio may be different but within the markings should be these numbers. UX245 is a 45 tube.
5 pin tubes with cap on top are 24's. In some cases they could have been replaced with 35 tubes which also work. 27's are 5 pin tubes without top caps. 45's and 80 are both 4 pin. Don't get these reversed. Two 45's will be mounted next to each other and the 80 by power transformer.
: I am working on an Atwater Kent Model 60 and am having a problem figuring out exactly what tubes the radio needs. I suspect that some of the tubes in the radio are not the correct ones. Any help here would be much appreciated.
: Thank you in advance.
: Nick Bettis
