: The component that is burning is leaking a light waxy type material, the component is shiny black with stripes, Yellow Violet Orange Grey and a space then Yellow? It is placed between pins 4 and 7 on a 35W4 Half wave rectifier..also atatched to one side of it is a 33ohm 3 watt resistor slightly burned but still measures 37 ohms. I had replaced a component earlier today a 220 ohm resistor wasn't sure originally if it was a 220 ohm or a 22 ohm as it was burned as well, looked to be 3 watt. It wasn't attached to the rect but was attached to the + of the 80uF filter cap but was so burned I couldn't be sure of the 3rd color black or brown...Anyway I replaced it and it worked for about 15 minutes then I heard a hum that slowly got louder and then smoke came out of the cabinet and it looks to be the component I described earlier.. All tubes tested good but I wonder if the 35W4 is sound under full voltage? Anyway anyone with a schem or any help greatly appreciated.. Thanx Brian
