:Check 18A 18B 18C resistors. those could have gone way up in value. Do check over your new capacitor connections. Positive sides join together, One negative side is ground, the other negative goes to field coil, and center tap of power transformer.
:It is possible to buy electrical dimmer switches with RFI suppression and they work quite well.The reason I know this is that one day I bought a dimmer switch that affected the radio when the other dimmer switches in my home didn't. After a little reading, I found out that switch wasn't protected. The ones with RFI suppression were only a couple bucks more.
Bob Masse
