:I know wire diameter and direction of turns are critical, but if that is covered can't you just rewind a coil based on resistance, or more clearly length instead of turns? The resistance/ft. is known value for any new wire.
:Most coils have windings on top of one another, so reistance per turn varies in a complicated way.
::I know wire diameter and direction of turns are critical, but if that is covered can't you just rewind a coil based on resistance, or more clearly length instead of turns? The resistance/ft. is known value for any new wire.
I guess you could measure the resistance of the original coil, and wind the same wire, in the same pattern, until you got to that resistance. But then, if you could measure the resistance of the original coil, why replace it in the first place? Huhh? Huhh? ;>)
:Doug,
:Don't you mean REACTANCE varies. Resistance per foot/turn is a fixed quantity, depending gauge of wire.
:marv
::Most coils have windings on top of one another, so reistance per turn varies in a complicated way.
:::I know wire diameter and direction of turns are critical, but if that is covered can't you just rewind a coil based on resistance, or more clearly length instead of turns? The resistance/ft. is known value for any new wire.
:Marv, maybe I misunderstood, but I though he was proposing to wind a coil without counting turns - just keep winding it until the resistance comes up to whatever it would be with a fixed ohms/turn.
:I guess you could measure the resistance of the original coil, and wind the same wire, in the same pattern, until you got to that resistance. But then, if you could measure the resistance of the original coil, why replace it in the first place? Huhh? Huhh? ;>)
::Doug,
::Don't you mean REACTANCE varies. Resistance per foot/turn is a fixed quantity, depending gauge of wire.
::marv
:::Most coils have windings on top of one another, so reistance per turn varies in a complicated way.
::::I know wire diameter and direction of turns are critical, but if that is covered can't you just rewind a coil based on resistance, or more clearly length instead of turns? The resistance/ft. is known value for any new wire.
:Because quite often there is more than one coil of the same value/resistance, and also the resistance of the coil is often on the schematic?
::Marv, maybe I misunderstood, but I though he was proposing to wind a coil without counting turns - just keep winding it until the resistance comes up to whatever it would be with a fixed ohms/turn.
::I guess you could measure the resistance of the original coil, and wind the same wire, in the same pattern, until you got to that resistance. But then, if you could measure the resistance of the original coil, why replace it in the first place? Huhh? Huhh? ;>)
:::Doug,
:::Don't you mean REACTANCE varies. Resistance per foot/turn is a fixed quantity, depending gauge of wire.
:::marv
::::Most coils have windings on top of one another, so reistance per turn varies in a complicated way.
:::::I know wire diameter and direction of turns are critical, but if that is covered can't you just rewind a coil based on resistance, or more clearly length instead of turns? The resistance/ft. is known value for any new wire.
Number of turns is what's important. If you unwind a coil and just rewind with the same length of wire unlikely that it's as smooth as original. Scramble wound takes more wire for the same number of turns.
DC resistance, as read on an ohm meter, makes little difference.
:::Doug,
:::marv
