I am wondering if someone has had success with soaking in some sort of solution that will etch away the tarnish.
It appears to be soft brass (not magnetic)
:I have a particularly elaborate and large escutcheon on a King battery set that is badly tarnished. It is high relief and wire brush will not work, nor will burnishing compounds.
:I am wondering if someone has had success with soaking in some sort of solution that will etch away the tarnish.
:It appears to be soft brass (not magnetic)
:I have used Brasso on other occassions. This piece really needs a dip to get the low areas.
http://housewares.hardwarestore.com/35-176-metal-polishes/tarn-x-tarnish-remover-101825.aspx
:Thanks all. My home made stew worked perfectly after sitting in it overnight.
:Will do Marv, although I was thinking about bottling it to sell as Bob's Secret Snake Oil Escutcheon Cleaner, Pimple Remover and Wonder Elixir.
Furthermore, when polishing, keep in mind that some manufacturers used colored lacquer (such as Van Dyke Brown) to 'antique' the brass. This is much easier than chemical antiquing. ...So if you wish, polish it to a high lustre, and if any antiquing is required, carefully air-brush it on. Then clear-coat over all.
