Kobe Kogyo model KT-80a
10/2/2009 12:06:50 AMDave Froehlich
Hello All,
Does anyone know of where I can find a schematic for this radio? I'm pretty sure it's the same as the KT-80. I cannot find the service data anywhere.
10/4/2009 8:10:40 AMDave Froehlich
Hello Again,
Seeing no response, I guess that such a schematic doesn't exist. But I still think it has to exist somewhere. Maybe there's some other radio that has another brand name on it that's exactly the same inside, and that has an available schematic.
:Hello All,
: Does anyone know of where I can find a schematic for this radio? I'm pretty sure it's the same as the KT-80. I cannot find the service data anywhere.
:Thanks,
:Dave
10/4/2009 8:17:58 AMDave Froehlich
Hello Again,
The company that made this radio is also called "TEN", if that helps at all.
:Hello Again,
: Seeing no response, I guess that such a schematic doesn't exist. But I still think it has to exist somewhere. Maybe there's some other radio that has another brand name on it that's exactly the same inside, and that has an available schematic.
:Thanks,
:Dave
::Hello All,
:: Does anyone know of where I can find a schematic for this radio? I'm pretty sure it's the same as the KT-80. I cannot find the service data anywhere.
::Thanks,
::Dave
10/4/2009 1:14:54 PMWarren
That 8 Transistor radio is also known as a " Play Rite "
Don't know if there is any service information. It's not any different from just about any 8 transistor radio though. If you are having problems with it, I would think it needs some new capacitors.
10/4/2009 1:17:30 PMDave Froehlich
Warren,
I already found that it's also called Play-Rite. but still cannot find a schematic under that name or under the "TEN" name. It's ok if it doesn't exist but it would be great to have one.
:That 8 Transistor radio is also known as a " Play Rite "
:Don't know if there is any service information. It's not any different from just about any 8 transistor radio though. If you are having problems with it, I would think it needs some new capacitors.
10/7/2009 6:19:03 PMDave Froehlich
Hello Again All,
This radio is a working radio. I still wish I could see the schematic.
:Warren,
: I already found that it's also called Play-Rite. but still cannot find a schematic under that name or under the "TEN" name. It's ok if it doesn't exist but it would be great to have one.
:Thanks,
:Dave
::That 8 Transistor radio is also known as a " Play Rite "
::Don't know if there is any service information. It's not any different from just about any 8 transistor radio though. If you are having problems with it, I would think it needs some new capacitors.
10/8/2009 1:53:12 AMWarren
I have a Philco NT-808 it's an 8 transistor AM radio. It has an RF amp front end, three stage IF, and push pull audio amp. Also a long ferrite rod antenna. This is probably a lot like yours. The schematic is here for Philco NT-808
http://techpreservation.dyndns.org/schematics/manufacturer.htm
