Multi cap 'lytic cans Redux
9/29/2009 6:37:54 PMWhammo!
I have a can that is marked 40-10-10 but no schematic. Is there any way to determine which leg is which on the bottom? They are all way out of spec :p
9/29/2009 9:33:38 PMNorm Leal
Hi
If it is metal can each terminal will be marked by a symbol, square, triangle etc. These symbols will be identified on side of the can.
:I have a can that is marked 40-10-10 but no schematic. Is there any way to determine which leg is which on the bottom? They are all way out of spec :p
9/29/2009 10:33:11 PMBOB BONCHAK
WHAMMO:
If you have determined that "they are all way out of spec", you should know which leg is 40 versus the two 10's. There will be significant, if relative, readings. In any event, seems like the cap is a candidate for re stuffing.
BOB
9/30/2009 11:26:03 PMplanigan
::I have a can that is marked 40-10-10 but no schematic. Is there any way to determine which leg is which on the bottom? They are all way out of spec :p
:WHAMMO:
:If you have determined that "they are all way out of spec", you should know which leg is 40 versus the two 10's. There will be significant, if relative, readings. In any event, seems like the cap is a candidate for re stuffing.
:BOB
