soldered cans for potted components ??
9/28/2009 10:32:26 AMChris
Hello all! Is it true that some of the component cans for potted chokes ,caps etc. are soldered shut and if so can they be opened by running a torch along the seam until solder melts and pulling lid off ??I don't want to use hack saw or rotary tool,besides how would you re-attach the lid after anyways? I have aquired a Westighouse Columnair amplifier power supply chassis from grandfather clock radio(from ebay) and it appears to have these soldered component cans.
9/28/2009 6:59:53 PMG. berg
What you can do is remove componet and use a small blow torch to unsolder joints.
:Hello all! Is it true that some of the component cans for potted chokes ,caps etc. are soldered shut and if so can they be opened by running a torch along the seam until solder melts and pulling lid off ??I don't want to use hack saw or rotary tool,besides how would you re-attach the lid after anyways? I have aquired a Westighouse Columnair amplifier power supply chassis from grandfather clock radio(from ebay) and it appears to have these soldered component cans.
