How do you know the power transformer is going out? It should be either good or bad, not weak. If hot it could have shorted turns or something in the circuit is drawing too much current.
If hot remove the 80 tube and allow the radio to operate for a half hour. Other tubes will be lit but the transformer should not get hot.
If you need a transformer rewound search the internet but cost will exceed $100.
Might find a replacement here:
: The power xformer in my 70 is going out, and I would like to know where to get it rewound. Thanks Mike.
:Hi Mike
: How do you know the power transformer is going out? It should be either good or bad, not weak. If hot it could have shorted turns or something in the circuit is drawing too much current.
: If hot remove the 80 tube and allow the radio to operate for a half hour. Other tubes will be lit but the transformer should not get hot.
: If you need a transformer rewound search the internet but cost will exceed $100.
: Might find a replacement here:
:http://www.oldradioparts.com/2a23efl.txt
:: The power xformer in my 70 is going out, and I would like to know where to get it rewound. Thanks Mike.
