Best Regards,
Bill Grimm
Please don't think I am trying to be picky, but I think he will measure around 47K between the IF secondary lead/tterminals. I believe there is a 47K Ohm resistor in series with the secondary winding. Just didn't want him to think the IF was bad because he measured several thousands Ohms resistance.
::My 7S633 is just dead. I can inject a signal into the grid of the 6P5 and get sound so seems like that is working from there on. When I put a scope on the grid of the 7A7 there is lots of signal there and I can then hear some station sound but not loud. When I remove the scope lead from the 7A7 grid there is no more station sound at all. Putting the scope on the 7B6 pins 5 and 6 I see no signal. Also, scope shows plenty of signal on the 7A7 plate. What could be wrong?
:Hi John,
: It seems you know where to take the readings.
: You stated, "Putting the scope on the 7B6 pins 5 and 6 I see no signal. Also, scope shows plenty of signal on the 7A7 plate." The big thing between is the output IF can.
: It could be leaky, out of tune or open. First check the voltage at the 7B6 detector plates. That should be negative. If it is positive, then current is leaking across the IF transformer. If that is OK, check the continuity of the secondary, 10 to 40 ohms. Yopu have continuity on the primary, else you wouldn't have signal on the 7A7 plate.
: If you have continuity and good voltage, it may just be out of tune.
:Best Regards,
:Bill Grimm
:Bill G.,
:Please don't think I am trying to be picky, but I think he will measure around 47K between the IF secondary lead/tterminals. I believe there is a 47K Ohm resistor in series with the secondary winding. Just didn't want him to think the IF was bad because he measured several thousands Ohms resistance.
:Radiodoc
:::My 7S633 is just dead. I can inject a signal into the grid of the 6P5 and get sound so seems like that is working from there on. When I put a scope on the grid of the 7A7 there is lots of signal there and I can then hear some station sound but not loud. When I remove the scope lead from the 7A7 grid there is no more station sound at all. Putting the scope on the 7B6 pins 5 and 6 I see no signal. Also, scope shows plenty of signal on the 7A7 plate. What could be wrong?
::Hi John,
:: It seems you know where to take the readings.
:: You stated, "Putting the scope on the 7B6 pins 5 and 6 I see no signal. Also, scope shows plenty of signal on the 7A7 plate." The big thing between is the output IF can.
:: It could be leaky, out of tune or open. First check the voltage at the 7B6 detector plates. That should be negative. If it is positive, then current is leaking across the IF transformer. If that is OK, check the continuity of the secondary, 10 to 40 ohms. Yopu have continuity on the primary, else you wouldn't have signal on the 7A7 plate.
:: If you have continuity and good voltage, it may just be out of tune.
::Best Regards,
::Bill Grimm
Looking at the schematic, from the diode plates to ground should measure around 500K or so Ohms to chassis/ground. I note that the secondary lead of the IF transformer may go thru a shield of sorts perhaps a braid or a spring looking shield. If the old brittle rubber wire was in the radio, there may be a partial short inside of the shield. Also there may be a problem with the fixed caps in I believe the base of the transformer.
:Before leaving for work this morning I measured from the plates, pins 5 &6, of the 7B6 to ground and it was only 80 ohms so someting is screwy there but will recheck tonight.
::Bill G.,
::Please don't think I am trying to be picky, but I think he will measure around 47K between the IF secondary lead/tterminals. I believe there is a 47K Ohm resistor in series with the secondary winding. Just didn't want him to think the IF was bad because he measured several thousands Ohms resistance.
::Radiodoc
::::My 7S633 is just dead. I can inject a signal into the grid of the 6P5 and get sound so seems like that is working from there on. When I put a scope on the grid of the 7A7 there is lots of signal there and I can then hear some station sound but not loud. When I remove the scope lead from the 7A7 grid there is no more station sound at all. Putting the scope on the 7B6 pins 5 and 6 I see no signal. Also, scope shows plenty of signal on the 7A7 plate. What could be wrong?
:::Hi John,
::: It seems you know where to take the readings.
::: You stated, "Putting the scope on the 7B6 pins 5 and 6 I see no signal. Also, scope shows plenty of signal on the 7A7 plate." The big thing between is the output IF can.
::: It could be leaky, out of tune or open. First check the voltage at the 7B6 detector plates. That should be negative. If it is positive, then current is leaking across the IF transformer. If that is OK, check the continuity of the secondary, 10 to 40 ohms. Yopu have continuity on the primary, else you wouldn't have signal on the 7A7 plate.
::: If you have continuity and good voltage, it may just be out of tune.
:::Best Regards,
:::Bill Grimm
Sir John. . . .
Just filling in to what has already mentioned:
If you have scoped a healthy RF . . IF signal being viewed at [A], along with your confirmation that an AF signal into [B] will drive the speaker healthily.
Then , my friend, you has done went and got's yourself the . . . . . "Dreaded, missing of [A] to [B] Syndrome."
Good to hear that there is no problem with the final DC coupled AF output circuitry, that boggles some peoples mind.
First electro / physical thing to check, would be the integrity of the wiring thru the shielded loop that I have marked up as [G].
One certainly would not want the high side of the IF output to not be getting thru to the det diodes.
The markup [C] is the origin point of your receive audio and it routes on down wards as shown and upwards to the 1st grid of the 7B6 at [D].
Note my markup of the tone control cluster switch in [FUSCIA] and check to see that nothing /nor/ parts are abnormal in that section, nor is there a mechanical problem with switch contacts or mechanical positioning to end up being between a contact function.
Now back to the observation of RF on the plate of the IF 7A7 via low capacitance scope coupling . . .and I doubt that you are going to be having a high bandwith sampling scope, such that you could be capable of watching each individual wavelet of a 455 signal.
But instead, you would be watching at ~1 MS hoz sweep timebase setting, where you merely be getting a compressed vertical amplitude display of the RF "grass" on the screen.
Now the question is, did you take observation of a couple of your strongest received stations, and confirm that there was the off station presence of a mere baseline, thus displaying an insignificant level of I.F. signal, whereas, when you tuned onto the stations, you did see the appreciable presence of signal amplitude,
An alternative would have to been having placed the scope vertical input in its DC coupling mode and monitored my [ F ] reference on the AVC buss and noticing an appreciable DC negative downwards swing of the baseline as a station was tuned into. Tuning off of the staton would result in its return upwards in a more positive direction .
If so, I would now suggest the use of 1 (or 2) jumper clips along with a .01 ufd cap and couple [C] to [B] and see if tning in of stations now result in some minor degree of audio.
That would be your injecting a quite high I.F. RF level into the detector and it should respond to that level of signal.
If so, then move to coupling the .01 between [C] and [D] and, hopefully, hold onto your socks.
If no results so far, then get your self a 47----220 pf silver mica or disc ceramic capacitor and connect between [A] and the two 7B6 detector diode plates that you see just past my [G] marking feeding into the 7B6.
If still no luck, lets make a quick and easy reassesment of your audio section test, but which you
seemed to have only evaluated the 6P5 onwards to the speaker.
Lets get back with the .01 and get a healthy ~18V P/P of a 60~ signal from any of the hot filament connections . .e.g. . . .[H]
Couple that 60~ signal via the .01 to [B] and a quick "match striking" touch should give one healthy HUMMMMM response .
If that works, assuredly it will, then you can inject from [H] to [C] and should the volume be at ite lowest setting and its then adjustment upwards should control the progressive HUMMM level.
If it doesn't, then you might attempt a quick touch from [H] to [D], but the signal will saturate and go into square wave clipping at the level limited by the plate load resistor . . .R14 . . .and will sound QUITE raspy.
That's about all but the possibility of a 7B6 problem, but the sig in -- sig out testing should confirm the triode amp section.
One could only confirm the tubes internal diodes aspect, by the temp subbing in of a solid state detector diode from the det plates connection to ground,
That would be with the subbing diodes anode going to the plates and its cathode going to ground.
Since you handle scopes your orientation is probably more towards SS circuitry, so a common 1N914---1N4148 are as common to have, as is sand to the beach.
Now,not being for RF use, but even one of the common 1N 4XXXX series power diodes would do in a pinch.
That would somewhat confirm, without having to go out and locate another 7B6.
(No longer a 7-Eleven
item at their old tube tester kiosk.)
Last thing would be passing us, the tube voltages around the 7B6 circuitry.
Standing by . . .
