This has 2 octal tubes (6V6 output, 6X5GT rectifier) and 7 - 7 pin minatures (6BE6, 6AB4 x 2, 6BA6 x 2, 6AV6 and 6AL5).
Any help would be most appreciated!
I have the AM section working with decent volume by retubing and by replacing the cathode resistor bypass capacitor, but changing the capacitor seems to have killed the very weak reception I was getting on FM.
Jim
http://www.olditemsale.com/truetone/truetone.htm
What you could do, is look through some of the makers schematics, for one that is the closest to yours.
For now I would check around the FM detector ( 6AV6 ) Values of resistors from the FM section. Of course those old capacitors.
