Sir Isaac. . . . .
Any chance that BLAUPUNKT receiver is using a Full Wave Bridge for the power supply rectifier ?
Plus this tube lineup:
EM87 Tuning eye
EL84 AF output
EABC80 Detector and 1st audio
EF89 IF amp
ECH81 Mixer-osc AM
ECC85 RF-Mixer FM
And is a 4 band receiver
And is about 1961 vintage
Is it in a Wood or plastic cabinet ?
SIR Isaac. . . . .
Ach himmel. . .I’m dun bin tellink you VOT . . .ve are bin havink undt big problink in locatink schmitt der schematic info fer der Svedish BLAUPUNKT 21050 .
I am thinkink I’m in findink it !
Check to see that the FM tuner is getting mechanically rotated my the frontal FM tuning knob.
If no FM reception, start by pulling the Ecc85 tube and scraping all of its pins . . .lengthwise . . .all around each pin . .clean and shiny as can be . . .right up to the glass bottom.
Then plug it in and out of its socket about 3 or 4 times and then fire up the set.
Go down to my YELLOW [A] mark up reference and monitor that grid looking for a negative voltage and then tune thru the FM band slowly. If the FM front end up to that point is working OK, there will be quite a noticeable increase in negative voltage as a station is tuned into, and then it will drop down as the stations is tuned off from.
If no sound, we must be losing it on past that point, on towards the detector and AF stages.
