Airline 62-233 Weak sound
9/18/2009 4:54:12 PMG. berg
Hi all I just recapped a Airline 62-233 and ONLY get a weak sound if I put my finger on the 6b7 tube. when I move tune I only get a high pitch sound which increases or decreases as I move to tune up or down. I check ALL coils, tubes, resistors...but can't get the dam thing to tune. I also made sure that rotar sections is not grounding out to chassis or rubbing. I rechecked my re-cap job and all seems to be correct to schematic....HMMMM any suggestions? THANKS!!!
9/18/2009 6:08:38 PMJohnnysan
:Hi all I just recapped a Airline 62-233 and ONLY get a weak sound if I put my finger on the 6b7 tube. when I move tune I only get a high pitch sound which increases or decreases as I move to tune up or down. I check ALL coils, tubes, resistors...but can't get the dam thing to tune. I also made sure that rotar sections is not grounding out to chassis or rubbing. I rechecked my re-cap job and all seems to be correct to schematic....HMMMM any suggestions? THANKS!!!
9/21/2009 10:20:04 PMvery productive comment
G. berg
::Hi all I just recapped a Airline 62-233 and ONLY get a weak sound if I put my finger on the 6b7 tube. when I move tune I only get a high pitch sound which increases or decreases as I move to tune up or down. I check ALL coils, tubes, resistors...but can't get the dam thing to tune. I also made sure that rotar sections is not grounding out to chassis or rubbing. I rechecked my re-cap job and all seems to be correct to schematic....HMMMM any suggestions? THANKS!!!
:Try replacing the grill cloth.
