RCA 6K console power transformer issue
9/16/2009 8:45:26 PMHutchclub
I'm working on a RCA 6K console that has a cooked power transformer, completely charred and burned, for a friend from work. It was his deceased brother's radio. I have done the usual re-cap and resistor check/replace and rewire as needed. However due to the power transformer condition I can not tell what replacement I should order. The schematic is not clear to me. Any help would be very much appreciated.
9/16/2009 10:54:29 PMNorm Leal
Hi
You need a transformer with 3 secondary windings. 6.3 volts @ 2.5 amps or more to light most of the tubes and lamps. 5 volts @ 2 amps for the rectifier filament. A high voltage winding. The original was 315-0-315 volts. I would look for 300-0-300 to 325-0-325 @ 70 ma.
Be sure the replacement fits on the chassis.
http://www.nostalgiaair.org/PagesByModel/099/M0015099.pdf
AES, www.tubesandmore.com , Radio Daze, www.radiodaze.com and PTOP, www.oldradioparts.com each sell power transformers for old radios.
:I'm working on a RCA 6K console that has a cooked power transformer, completely charred and burned, for a friend from work. It was his deceased brother's radio. I have done the usual re-cap and resistor check/replace and rewire as needed. However due to the power transformer condition I can not tell what replacement I should order. The schematic is not clear to me. Any help would be very much appreciated.
9/17/2009 8:57:16 AMhutchclub
Thanks for your help Norm. I can move forward on this project now.
I really appreciate all the help and knowledge I have learned from this forum.
:Hi
: You need a transformer with 3 secondary windings. 6.3 volts @ 2.5 amps or more to light most of the tubes and lamps. 5 volts @ 2 amps for the rectifier filament. A high voltage winding. The original was 315-0-315 volts. I would look for 300-0-300 to 325-0-325 @ 70 ma.
: Be sure the replacement fits on the chassis.
:http://www.nostalgiaair.org/PagesByModel/099/M0015099.pdf
: AES, www.tubesandmore.com , Radio Daze, www.radiodaze.com and PTOP, www.oldradioparts.com each sell power transformers for old radios.
::I'm working on a RCA 6K console that has a cooked power transformer, completely charred and burned, for a friend from work. It was his deceased brother's radio. I have done the usual re-cap and resistor check/replace and rewire as needed. However due to the power transformer condition I can not tell what replacement I should order. The schematic is not clear to me. Any help would be very much appreciated.
