6/12 volt power supply??
3/25/2001 3:06:09 PMDennis Lavin
I am looking for a 6volt /12volt power supply sutible for running old car radios on my test bench. Or a plan to build one. Any help will be appreciated! Dennis.
3/26/2001 11:27:16 PMJohn McPherson
Your simplest solution is to buy a 5 amp battery charger, and simply add a "Pi" filter. Take a choke from an old TV, and use two electrolytics, 1000 Mfd to 3000 Mfd with a working voltage of 18-35 volts.
: I am looking for a 6volt /12volt power supply sutible for running old car radios on my test bench. Or a plan to build one. Any help will be appreciated! Dennis.
4/1/2001 8:20:30 AMDennis Lavin
: Hi,
: Your simplest solution is to buy a 5 amp battery charger, and simply add a "Pi" filter. Take a choke from an old TV, and use two electrolytics, 1000 Mfd to 3000 Mfd with a working voltage of 18-35 volts.
Thanks for the info!!
: : I am looking for a 6volt /12volt power supply sutible for running old car radios on my test bench. Or a plan to build one. Any help will be appreciated! Dennis.
8/8/2002 4:18:58 PMTom Webster
:Hi,
:Your simplest solution is to buy a 5 amp battery charger, and simply add a "Pi" filter. Take a choke from an old TV, and use two electrolytics, 1000 Mfd to 3000 Mfd with a working voltage of 18-35 volts.
: John: I found your posting. Thanks for the wonderful and simple idea. I needed a 6volt 5 amp power source, and this will just be great.
Tom Webster
:: I am looking for a 6volt /12volt power supply sutible for running old car radios on my test bench. Or a plan to build one. Any help will be appreciated! Dennis.
8/8/2002 4:19:07 PMTom Webster
:Hi,
Tom Webster
