Some notes on the unit: The wooden case is in good shape, though missing 2 knobs. The back panel is missing. The speaker cone has 2 large tears in it. The unit currently works, though poorly (I hadn't yet found the "don't power it up" advice before I did so).
I have seen several sites detailing the steps involved in other restorations and have located the schematics for the unit.
Can anyone offer advice on this project? First of all, how much effort is this model worth? I think it'd be fun to replace all the wiring and components and have it all shiny new, though I don't want to get myself in too deep.
Should I leave the old capacitors in to hide the new ones, or should I just clip them out?
The label on the bottom is peeling off. What is the best way to reattach? Clear-drying glue? A coat of varnish?
Finally, the speaker has 2 large tears in it. I've seen mentions of gluing tears in the cones. Should I attempt this? I don't know if I want to go for the $50 reconing for this.
Some images:
front:
http://imgur.com/vDDNv
label:
http://imgur.com/2JKmO
Thanks for any advice you can offer
Mike
http://radioatticarchives.com/radio.htm?radio=7222
:That's a fine radio to start off with. Replace all the old paper capacitors, don't leave to old ones in. If the speaker is still working, you can just patch it with paper. Rubber cement is okay. For that plastic dial cover, you could use wadding polish called " Nevr-Dull " For replacement knobs there are reproduction ones. I think the GE models used about the same type looking ones. For the bottom label, clear lacquer is fine. The matter of " worth " that only means what it's worth to you. Sometimes " value " is the self satisfaction restoring an old radio. Here is a picture of what it should look like. Good luck, hope you have some fun with this hobby.
:http://radioatticarchives.com/radio.htm?radio=7222
