Sir Dave. . . .
The picking up of several different AM signals would tend to signify that the frontal RF and first IF stages are OK
in alignment.
After that, there is just the RF signal at the plate circuitry of the IF amp that feeds into the AM detector circitry.
With some known problems of 6T8's, can you sub in another unit for it ?(considering only,its sole AM det diode section)
(Another viable test is to shunt the det diode section of the 6T8 with a solid state det diode . . . .1N914-4148.) [Its anode going to plate-its cathode to ground] If it then more efficiently, detector rectifies, go for it.
One then sees that the audio is all handled the same . . . .gain wise . . . from the band switch over to the top side of the volume control and thru the auduio circuitry.
Also, can you check the peaked tuning of the 2nd AM IF transformers plate coil and the following detector grid coil winding ?
Could even be a def 2nd AM IF transformer.
