http://www.the-s38-guy.com/
:You can download the manual with good schematic for an S-38C from this site. You do have the connections correct for a long wire. You will need more than 6 feet though. 15 to 20 feet and outside is better. Clean the rotary switch, give it some exercise by rotation a bunch of times. dirty tube sockets, remove the tubes and clean pins and sockets. You should recap it. Remember that the S-38C has the B- buss line, Not chassis ground like the S-38B & A Here is a good link with tips for S-38 line
:http://www.the-s38-guy.com/
