Lou
:Fuse the Primary side too.
In all the years I have used my Columbia console radio, the 82 has never failed.
:Lou
::Fuse the Primary side too.
Just put a silicon diode in series with each plate. Use a 600 volt 1 amp type and you're good to go. The fuse on the secondary is also an excellent idea.
:::Starting work on a Crosley 146, which has an 82 rectifier. Other than fusing the secondary of the power transformer, is there a way to reduce damage from a failure of the 82? Any thoughts would be appreciated...
If Ii recall, the drop across a silicon diode is about one-tenth that of a mercury vapor rectifer.
:Just put a silicon diode in series with each plate. Use a 600 volt 1 amp type and you're good to go. The fuse on the secondary is also an excellent idea.
::::Starting work on a Crosley 146, which has an 82 rectifier. Other than fusing the secondary of the power transformer, is there a way to reduce damage from a failure of the 82? Any thoughts would be appreciated...
