1.5 volt A battery for 2 volt filament
9/6/2009 11:44:20 AMChris
I have a farm battery radio that requires 2 volts for the filaments of tubes.Is it okay to use 1.5 volt batteries or is this too low or cause cathode stripping etc. If not I could put to 1.5 batteries in series with resistor to bring down to 2 volts.
9/6/2009 11:57:12 AMNorm Leal
Hi Chris
Although 2 volt tubes can operate on 1 1/2 volts in audio circuits the radio oscillator most likely will not. Use 2 - 1 1/2 volt batteries in series for your two volt tubes. May need a few ohms in series to drop voltage if there isn't enough drop in the wiring?
:I have a farm battery radio that requires 2 volts for the filaments of tubes.Is it okay to use 1.5 volt batteries or is this too low or cause cathode stripping etc. If not I could put to 1.5 batteries in series with resistor to bring down to 2 volts.
9/7/2009 9:39:31 PMWarren
If you were to use two Nickel Cadmium Cells, those are only 1.2 volts each. Would = 2.4 volts. That should be fine for filaments. Not mention rechargeable.
9/8/2009 9:06:20 AMChris
:If you were to use two Nickel Cadmium Cells, those are only 1.2 volts each. Would = 2.4 volts. That should be fine for filaments. Not mention rechargeable.
:Thankyou Norm and Warren for info!!
