maximum plate voltage on 01A tube
9/6/2009 6:14:38 AMChris
Greetings!What is the average or maximum plate voltage for a 01A tube?Thanks for any info.
9/6/2009 7:03:18 AMscott
Good info right here.
http://www.nostalgiaair.org/tubes/01a.htm
9/6/2009 7:22:42 AMscott
Here is another good site.
http://www.nj7p.org/Tube4.php?index=1
9/6/2009 10:20:48 AMDoug Criner
The typical voltage is 90V, but the tube can be run at 135V. The C- grid bias has to be greater (more negative) for higher B+.
When an '01A is used as a detector, the plate voltage should be lower, maybe 22.5V or 45V. The schematic for each radio should specify the battery voltages.
Doug
:Greetings!What is the average or maximum plate voltage for a 01A tube?Thanks for any info.
9/8/2009 9:08:24 AMChris
:The typical voltage is 90V, but the tube can be run at 135V. The C- grid bias has to be greater (more negative) for higher B+.
:When an '01A is used as a detector, the plate voltage should be lower, maybe 22.5V or 45V. The schematic for each radio should specify the battery voltages.
:Doug
:Thankyou Scott and Doug for the information!!!
::Greetings!What is the average or maximum plate voltage for a 01A tube?Thanks for any info.
