: 4 1/2" meters are getting hard to find, if this is what you have.
: A continuity check across the meter terminals may show continuity as some milliammeters use a shunt in parellel to the meter armature winding.
: If one can't be had, I'd try repairing the one that you have.
: It is a lot like wrist-watch repair (it is in fact a tiny electric motor). Be gentle, sit steady and comfortably and use a magnifier to see. I've been both lucky and unlucky with them. It may be a poor connection at the fulcrum pivot or other simple repair. I have yet to find an open winding in one.
http://www.gvtc.com/~edengel/TV7Meter.htm
: I have considered a digital replacement of failed S-meters (there was an article about adding a digital S-meter to a Hallicrafters S-38) and test meters). I've put those projects on the backburner while I thought about it.
: A kinked hairspring would be in the jewellers realm, you may want to show what you have to one and get suggestions. He may have an appropriate replacement hairspring and the tools to replace it with. Does your meter have a hairspring on the front and rear of the armature so he could use the good one as a reference?
