:I was thinking maybe these pics might help explain my mystery set a little better.. Thank you everyone for your help and input! still no real answer yet.. and I have looked at hundred or so schematics..have some close guesses...
:Don, if that's electro-magnetic speaker you would need five: 1.Gnd 2. 2 wires field coil 3. 1 output Xfmr and 4. 1 spkr coil. How many wires are attached to the plug? PL
::I was thinking maybe these pics might help explain my mystery set a little better.. Thank you everyone for your help and input! still no real answer yet.. and I have looked at hundred or so schematics..have some close guesses...
why - you might have a piece of grill cloth or soldering iron tip that might fit that radio? LMAOOOOOOOOOOOOOOOO as if you can identify the radio or offer help. you cant even determine capacitor values in a block assembly without pathetically asking for help over and over and over.
::could you post a pic of the complete chassis and or cabinet?
:why - you might have a piece of grill cloth or soldering iron tip that might fit that radio? LMAOOOOOOOOOOOOOOOO as if you can identify the radio or offer help. you cant even determine capacitor values in a block assembly without pathetically asking for help over and over and over.
The only observations that I can make is that no one is going to put that plug in an AC outlet.
Terry F
![]() : : : :Sir DON . . . . . : : : : :The only observations that I can make is that no one is going to put that plug in an AC outlet. : : :Chassis 5 pin jack . . .With three degrees of digital enhancement I can then clearly make out SPEAKER and upside down SPEAKER. : : : BTW . . .I just LUV's those 'lebenteen carrots gold plated knob-ses. : : :The next best option on further photos should be of a close up of the inside of the chassis at that plug and the wires routes outwardly from it. : : :A top of the chassis photo, to identify the position of the audio output transformer. : : :Unless you have them waaaaaay back on another post, we don't know the tube lineup also. : : : : : : :73's de Edd : : : : ![]() : |
http://www.neonradio.com/restorations.html
