potter square metal caps
8/31/2009 9:05:24 PMDon
Anybody have info on these? do they wear out and need relacing? or are they like mica caps and never really need to be replaced? The ones in my unidentified set are unmarked so I dont know the values... agravating!!
8/31/2009 10:09:58 PMRadiodoc
Don,
If they look something like the ones here:
http://www.surplussales.com/Capacitors/BathtubCaps.html
then they are most likely paper type capacitors (condensers) and they can become leaky or short just like the tubular paper-wax time seen most often. Some are sealed in a tar like substance and some are completely sealed in metal with the bottom cover soldered in place.
:Anybody have info on these? do they wear out and need relacing? or are they like mica caps and never really need to be replaced? The ones in my unidentified set are unmarked so I dont know the values... agravating!!
9/1/2009 11:03:28 AMDon
yes they are..now to figure out the values...
:Don,
:If they look something like the ones here:
:http://www.surplussales.com/Capacitors/BathtubCaps.html
:then they are most likely paper type capacitors (condensers) and they can become leaky or short just like the tubular paper-wax time seen most often. Some are sealed in a tar like substance and some are completely sealed in metal with the bottom cover soldered in place.
:Radiodoc
::Anybody have info on these? do they wear out and need relacing? or are they like mica caps and never really need to be replaced? The ones in my unidentified set are unmarked so I dont know the values... agravating!!
9/1/2009 1:06:36 PMWarren
What circuit are they connected to? Maybe if you draw out this part of the circuit, compare to a similar radio schematic. That should give you at least an idea.
9/1/2009 11:07:32 PMDon
thanks for the tip!
:What circuit are they connected to? Maybe if you draw out this part of the circuit, compare to a similar radio schematic. That should give you at least an idea.
