BRASSO
8/24/2009 2:53:02 PMAndrew
Peter, I must have used the wrong kind of BRASSO. The more I polished the DULLER it became. Are there two kinds of Brasso???
8/24/2009 9:51:56 PMWarren
I have never seen but one brand and type of Brasso. Never have tried it on a radio cabinet before. Sounds like it should have worked as per what others have said about it. Could be your cabinet is not of the true bakelite. One other thing i have used though, is a wadding polish called " Nevr-Dull " this is really for silverwear, but it works real good on plastics too. Even brings back those dull head light covers on your car. Could give this a try, or blue coal auto polish. Even that liquid called " New Finish " in an orange bottle. Could even give it a final wax for all the luster you want.
8/24/2009 10:59:54 PMPeter G. Balazsy
:I have never seen but one brand and type of Brasso. Never have tried it on a radio cabinet before. Sounds like it should have worked as per what others have said about it. Could be your cabinet is not of the true bakelite. One other thing i have used though, is a wadding polish called " Nevr-Dull " this is really for silverwear, but it works real good on plastics too. Even brings back those dull head light covers on your car. Could give this a try, or blue coal auto polish. Even that liquid called " New Finish " in an orange bottle. Could even give it a final wax for all the luster you want.
You should try a small spot a few inches.. then rub it around very well and buff off with clean dry cloth...
It should be fine.
8/25/2009 12:20:13 AMMarv Nuce
Andrew,
I just used "Soft Scrub" (mild paste Comet cleanser) after #400 dry sanding to polish plastic (celluloid??) white keys from an old organ. For a heavier cut, use #0000 steel wool with Soft Scrub. Rubbing compound from automotive supply will also do.
:Peter, I must have used the wrong kind of BRASSO. The more I polished the DULLER it became. Are there two kinds of Brasso???
8/25/2009 2:12:28 PMhmmm marv is polishing his old organ
marv needs to find a woman before he makes him self blind LMAO
:Andrew,
:I just used "Soft Scrub" (mild paste Comet cleanser) after #400 dry sanding to polish plastic (celluloid??) white keys from an old organ. For a heavier cut, use #0000 steel wool with Soft Scrub. Rubbing compound from automotive supply will also do.
:marv
::Peter, I must have used the wrong kind of BRASSO. The more I polished the DULLER it became. Are there two kinds of Brasso???
8/26/2009 12:33:41 AMMarv Nuce
Not to worry, I'm half blind anyway, and it hurts SO GOOD.
:marv needs to find a woman before he makes him self blind LMAO
::Andrew,
::I just used "Soft Scrub" (mild paste Comet cleanser) after #400 dry sanding to polish plastic (celluloid??) white keys from an old organ. For a heavier cut, use #0000 steel wool with Soft Scrub. Rubbing compound from automotive supply will also do.
::marv
:::Peter, I must have used the wrong kind of BRASSO. The more I polished the DULLER it became. Are there two kinds of Brasso???
