This idea may be a help to those who are stuck for effective dial solutions too.
The outer gold part on the glass dial was fine.. only the white numerals were flaking off.
note:(I thought I might have already showed this decal technique here some time ago but I couldn't find it anywhere so I put this together today.)
Because the white dial numbers were so bad and I made it worse trying to clean it... so...I was straining my brain trying to come up with a way to make the WHITE numbers.... but in a flash of creativity I thought..Why White?.. why not Black??
Contrast was the key element here. So I made a bright red background with red electrical tape ... mostly because I really liked that soft shade of red and it was an easy way to get it.
Then I completely redesigned the dial numbers. I used a font I thought was appropriate and actually squeezed and condensed it to make it a bit funkier. Then I created the black numbers on a clear field in reverse.
Then I floated the water-slide decal into place on the back of the dial glass and sealed it with clear lacquer.
If I remember correctly ....I think? ...this is one of the natural-color Bakelite radios that I also used lacquer on the cabinet too.
( I do so many radios ...sometimes they all blur together..lol)
After rubbing my fingers raw buffing this up to perfect using Brasso... I wiped it all down and washed it to remove any surface polish. Then wiped it with alcohol and sprayed it with clear gloss lacquer to preserve this state of beauty.
I feel that if any radio was ever given a chance to look 'new' again.. this is one of them.
Compared to my ''painted'' radios this is a natural beauty.. right?
Oddly though ... as beautiful as this is.. and as perfect-looking and original as it looks... Some time ago when I had it up on Ebay for a week.... I couldn't find anyone ready to part with any more than about $80.... so here it sits.. on my shelf again.
Hate to put all that sweat-equity into a radio and loose money in the process... right?
I'm not about to give it away either...lol.
:After posting the other natural Bakelite RCA 56x10 the other day I was reminded of another beautiful Radiola 76ZX11 I did not long ago that sat around on my bench for quite a while until I came up with a solution for the glass dial numerals that started flaking off.
:This idea may be a help to those who are stuck for effective dial solutions too.
:The outer gold part on the glass dial was fine.. only the white numerals were flaking off.
:note:(I thought I might have already showed this decal technique here some time ago but I couldn't find it anywhere so I put this together today.)
:Because the white dial numbers were so bad and I made it worse trying to clean it... so...I was straining my brain trying to come up with a way to make the WHITE numbers.... but in a flash of creativity I thought..Why White?.. why not Black??
:Contrast was the key element here. So I made a bright red background with red electrical tape ... mostly because I really liked that soft shade of red and it was an easy way to get it.
:Then I completely redesigned the dial numbers. I used a font I thought was appropriate and actually squeezed and condensed it to make it a bit funkier. Then I created the black numbers on a clear field in reverse.
:Then I floated the water-slide decal into place on the back of the dial glass and sealed it with clear lacquer.
:If I remember correctly ....I think? ...this is one of the natural-color Bakelite radios that I also used lacquer on the cabinet too.
: ( I do so many radios ...sometimes they all blur together..lol)
:After rubbing my fingers raw buffing this up to perfect using Brasso... I wiped it all down and washed it to remove any surface polish. Then wiped it with alcohol and sprayed it with clear gloss lacquer to preserve this state of beauty.
:I feel that if any radio was ever given a chance to look 'new' again.. this is one of them.
:Compared to my ''painted'' radios this is a natural beauty.. right?
:Oddly though ... as beautiful as this is.. and as perfect-looking and original as it looks... Some time ago when I had it up on Ebay for a week.... I couldn't find anyone ready to part with any more than about $80.... so here it sits.. on my shelf again.
:Hate to put all that sweat-equity into a radio and loose money in the process... right?
: I'm not about to give it away either...lol.
:Are you going to post this on on Ebay also...I might wana buy?
::After posting the other natural Bakelite RCA 56x10 the other day I was reminded of another beautiful Radiola 76ZX11 I did not long ago that sat around on my bench for quite a while until I came up with a solution for the glass dial numerals that started flaking off.
::This idea may be a help to those who are stuck for effective dial solutions too.
::The outer gold part on the glass dial was fine.. only the white numerals were flaking off.
::note:(I thought I might have already showed this decal technique here some time ago but I couldn't find it anywhere so I put this together today.)
::Because the white dial numbers were so bad and I made it worse trying to clean it... so...I was straining my brain trying to come up with a way to make the WHITE numbers.... but in a flash of creativity I thought..Why White?.. why not Black??
::Contrast was the key element here. So I made a bright red background with red electrical tape ... mostly because I really liked that soft shade of red and it was an easy way to get it.
::Then I completely redesigned the dial numbers. I used a font I thought was appropriate and actually squeezed and condensed it to make it a bit funkier. Then I created the black numbers on a clear field in reverse.
::Then I floated the water-slide decal into place on the back of the dial glass and sealed it with clear lacquer.
::If I remember correctly ....I think? ...this is one of the natural-color Bakelite radios that I also used lacquer on the cabinet too.
:: ( I do so many radios ...sometimes they all blur together..lol)
::After rubbing my fingers raw buffing this up to perfect using Brasso... I wiped it all down and washed it to remove any surface polish. Then wiped it with alcohol and sprayed it with clear gloss lacquer to preserve this state of beauty.
::I feel that if any radio was ever given a chance to look 'new' again.. this is one of them.
::Compared to my ''painted'' radios this is a natural beauty.. right?
::Oddly though ... as beautiful as this is.. and as perfect-looking and original as it looks... Some time ago when I had it up on Ebay for a week.... I couldn't find anyone ready to part with any more than about $80.... so here it sits.. on my shelf again.
::Hate to put all that sweat-equity into a radio and loose money in the process... right?
:: I'm not about to give it away either...lol.
http://www.kromepaint.com/decalpaper.html
They have a whole section there if you look around on how to use the decals for reverse or whatever.. very helpful.
