(No Subject)
8/11/2009 8:57:39 PMVinny
Greetings to all, what do you wood radio guru's use when re-glueing a grill cloth back into a radio? I would tend to think wood glue? Duco cement?
Vinny A.
8/11/2009 8:58:50 PMVinny
oops, sorry for not posting a topic.
8/11/2009 9:27:07 PMdan livesay
:Greetings to all, what do you wood radio guru's use when re-glueing a grill cloth back into a radio? I would tend to think wood glue? Duco cement?
:Vinny A.
:Hello: I have found that Elmers spray adhesive is hard to beat. It will not bleed through and can be moved around if needed with no problem ***.
8/12/2009 12:16:13 AMMarv Nuce
Vinny,
I use something slow setting, because when you turn it around to the view side, you'll find distortion in the pattern, requiring adjustment. Elmers white glue allows this, and I prefer the Elmers "Fabric an Paper" glue because it's waterproof, and dries flexible.
:Vinny A.
8/12/2009 9:19:52 PMVinny-Thank you Dan and Marv
Thank you Dan and Marv for your suggestions.
Best wishes,
Vinny A.
