Best Regards,
Bill Grimm
:Hi Vinny,
: I have done it. With H-K shorts, however, it is difficult.
: One class of shorts, cold heater shorts can be measured with an ohm meter. They are rare, but I have a 12AT7 here that has one. It caused a radio to explode (35C5 and 6BJ6 shattered). Good thing they are rare.
: I have a 19T8 which had a short between its cathodes. When running I can measure around 1 meg between the cathodes.
: If you want to get a good idea of where an H-K short is and where it is located, this can be done. Run the tube off of DC at it normal voltage. Connect a current meter from cathode to ground and take a reading. Then connect the current meter from cathode to filament positive.
: I am assuming here that the H-K short isn't so severe as to damage the current meter. Usually they are not.
: Using ohms law you can get an idea of how severe the short is, and where it is located on the filament.
: I had a 6F6 in my Zenith 5S127 with an H-K short. The cathode is grounded, and the short was near the side of the filament that is grounded. Because of this the tube is not a problem. It worked OK and didn't overload the power supply. It was like that for quite a while. Several months ago I tested the tube again and the short is gone.
:Best Regards,
:Bill Grimm
You could check for direct shorts with a meter but most shorts/high leakage only show after a tube warms. It's not worth checking for shorts with a meter. Too msny combinations and almost no tubes will fail this test.
:About an hour ago I tested a philco model 45. It had a 80GT tube in it. It powered up, hummed then blew the fuse. I tested the 80GT, initally no shorts, after 1 minute shorts between plate and filliment. I let it cool down and the short went away. interesting tube though it has the envelope of an eye tube, and plates that look like a 6ca4, and I can see a cathode around the filiment. There is a hole melted through the cathode. The radio had a bad power transformer when I got it,luckily it dosent need another one after today.
::Hi Vinny,
:: I have done it. With H-K shorts, however, it is difficult.
:: One class of shorts, cold heater shorts can be measured with an ohm meter. They are rare, but I have a 12AT7 here that has one. It caused a radio to explode (35C5 and 6BJ6 shattered). Good thing they are rare.
:: I have a 19T8 which had a short between its cathodes. When running I can measure around 1 meg between the cathodes.
:: If you want to get a good idea of where an H-K short is and where it is located, this can be done. Run the tube off of DC at it normal voltage. Connect a current meter from cathode to ground and take a reading. Then connect the current meter from cathode to filament positive.
:: I am assuming here that the H-K short isn't so severe as to damage the current meter. Usually they are not.
:: Using ohms law you can get an idea of how severe the short is, and where it is located on the filament.
:: I had a 6F6 in my Zenith 5S127 with an H-K short. The cathode is grounded, and the short was near the side of the filament that is grounded. Because of this the tube is not a problem. It worked OK and didn't overload the power supply. It was like that for quite a while. Several months ago I tested the tube again and the short is gone.
::Best Regards,
::Bill Grimm
