You may have to work from a set of similar schematics. I wonder if the schematics for the Crosley 51 and Trydyne in the schematics section of this site would help. They cover 2 and 3 tube radios that would use 199's or 01A's. I think radios of that era were all very similar.
Ed.
A radio using three triodes isn't that complicated, I should be able to figure this out without too much
trouble. The schematics you suggested are similar. In this case a schematic probably wouldn't really help
much because component values aren't listed on most of the old schematics anyway.
I remember in 1969 I was working with an old radio repairman that told me one day that Howard Sams had
ruined a lot of good technicians. When I asked what he meant by that he said everyone was so used to having
a schematic with all the voltages and values that they couldn't figure anything out for themselves any more.
Thanks again, I guess I will figure this one out for myself.
Dennis
: Hi, I have looked in the Radio College of Canada schematic books and find that your radio is too early to have been included in them.
: You may have to work from a set of similar schematics. I wonder if the schematics for the Crosley 51 and Trydyne in the schematics section of this site would help. They cover 2 and 3 tube radios that would use 199's or 01A's. I think radios of that era were all very similar.
: Ed.
: Thanks for looking in the Radio College of Canada books, I don't have access to them.
: A radio using three triodes isn't that complicated, I should be able to figure this out without too much
: trouble. The schematics you suggested are similar. In this case a schematic probably wouldn't really help
: much because component values aren't listed on most of the old schematics anyway.
: I remember in 1969 I was working with an old radio repairman that told me one day that Howard Sams had
: ruined a lot of good technicians. When I asked what he meant by that he said everyone was so used to having
: a schematic with all the voltages and values that they couldn't figure anything out for themselves any more.
: Thanks again, I guess I will figure this one out for myself.
: Dennis
: : Hi, I have looked in the Radio College of Canada schematic books and find that your radio is too early to have been included in them.
: : You may have to work from a set of similar schematics. I wonder if the schematics for the Crosley 51 and Trydyne in the schematics section of this site would help. They cover 2 and 3 tube radios that would use 199's or 01A's. I think radios of that era were all very similar.
: : Ed.
UX199 is the same tube. The later designation for this tube would be X99. If you reduce filament to 2 volts you could substitute #30 tubes.
Resolder the two large pins on your open tube. Sometimes it's only a wire to pin contact problem.
: I have a Canadian Westinghouse 53 Regenerative receiver with a patent date 1922. It uses three WX199 tubes.
: Is it correct to assume that this is the same as a UX199? (one filiment is open) I have not repaired very many
: of the old battery operated sets and it would be very helpful if someone could direct me to a schematic for this radio.
I usually don't work on radios quite this old but this one originally belonged to my father-in-law and I decided it would be fun to make it work again.
I didn't get lucky with my tube, resoldering the pins didn't fix it. I will have to find a replacement.
Dennis
: Hi Dennis
: UX199 is the same tube. The later designation for this tube would be X99. If you reduce filament to 2 volts you could substitute #30 tubes.
: Resolder the two large pins on your open tube. Sometimes it's only a wire to pin contact problem.
: Norm
: : I have a Canadian Westinghouse 53 Regenerative receiver with a patent date 1922. It uses three WX199 tubes.
: : Is it correct to assume that this is the same as a UX199? (one filiment is open) I have not repaired very many
: : of the old battery operated sets and it would be very helpful if someone could direct me to a schematic for this radio.
